Atv doing nothing
Old Feb 28, 2010 | 04:25 PM
GRAYNELLR's Avatar
Default Atv doing nothing
Atv have been sitting up for a while put a new battery in and nothing everything was working before. Can any help btw it a hi bird 250
Old Feb 28, 2010 | 10:11 PM
outofline's Avatar
New Battery needs a charge? Or Jump with another battery? Main Fuse is blown? So no lights light up at all?
May need to pull clutch lever or brake lever in to start!
Old Mar 1, 2010 | 10:46 AM
LynnEdwards's Avatar
Electrical Expert
I agree with everything outofline said above.
Another thing you might try:
Follow the large red battery wire to the starter solenoid post. Follow the other solenoid post down to the starter motor. Short those two posts together with a screwdriver (some sparking is OK). Does the starter turn?
If yes, then you battery is OK and we can look at the ignition / starter interlock circuitry. If the starter doesn't turn then it points to battery problems, starter problems, or bad connections in the starter wiring (including the ground return).
Old Mar 18, 2010 | 12:40 PM
KTB's Avatar
KTB
I am very new here and know almost nothing about these quads,,BUT the problem you describe i did have. For me the fix was a fuse that was located right below the seat inline of the smaller red wire coming off the battery,, the fuse looked fine, but wasnt working, swapped fuse and BAM i have electic,,hope that helps.
