1995 400 4x4
Old Mar 18, 2010 | 07:33 PM
schwarry's Avatar
Default 1995 400 4x4
I have coolant dripping out of the starter. Does anyone know what this might mean?
Old Mar 18, 2010 | 09:11 PM
ftwflh's Avatar
Water pump seal and/or counter balace is bad
Old Mar 18, 2010 | 09:17 PM
schwarry's Avatar
I was worried about a cracked block. Can the water pump seal be replaced, or is this something that needs to be totally replaced?
Old Mar 19, 2010 | 05:59 AM
ftwflh's Avatar
The seals can be replaced if the shaft is not ruined
Old Mar 19, 2010 | 06:21 AM
schwarry's Avatar
Thank You.
What should I look for to see if the counterbalancer is bad? The seal looks like a simple fix, but I'm not sure what to look for that will tell me if the counterbalancer will have to be replaced. When I remove the plug, it almost looks like rusty water on the plug. Do I also have a head gasket problem?
Thanks again.
Old Mar 21, 2010 | 09:00 PM
schwarry's Avatar
I've removed the motor, and tried the tool to pull the clutch off. It has stripped the 3/4" threads inside. Is there any other way to pull this off?
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
bubbagodkin
Jul 12, 2000 01:06 AM
bubbagodkin
Jul 6, 2000 07:46 PM
