atc 110 trany oil??
Old Mar 26, 2010 | 07:41 PM
TJ110's Avatar
Default atc 110 trany oil??
Dont have a manual. What oil is best to use in the automatic clutch tranny of my 83 atc 110?
Old Mar 28, 2010 | 12:07 AM
posty2100's Avatar
I like the Honda GN-4 oil I get from local dealer. Another one I like is Valvoline Atv Oil which is good for wet clutchs which is what the auto clutch is. You can use mostly any ATV/Motorcycle oil. I don't recommend using just regular like 10w40 motor oil but many use it because its usually cheaper and easier to buy.
"Valvoline ATV oil contains a proprietary blend of premium base oils and advanced additive technology to help you get the most from your ATV.
Extreme Condition Performance - Thermally stable formula maintains proper lubrication to protect engines under extreme conditions.
Wet Clutch Protection - Optimal frictional characteristics for high torque, smooth shifting and proper protection of the wet clutch.
Corrosion Resistance - Advanced additives help protect against water, deposits and other corrosive materials to keep engines clean.
Maximum Horsepower - Proper additive balance for maximum horsepower.
Minimal Wear - Increased anti-wear agents minimize wear from metal-to-metal contact.
Shear Stability - Shear stable viscosity improvers better resist oil film breakdown"
Old Mar 28, 2010 | 10:13 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum TJ110!
Your 110 will be happy with Valvoline 10wt-40.. and so will your wallet..
450rking
May 14, 2006 11:02 AM
dwright
Jan 21, 2006 01:45 PM
hadaveha
Dec 28, 2005 01:31 AM
ATVBos
Dec 29, 2004 02:21 AM
bvwarrior
Jul 5, 2004 01:26 AM
