warrior wont start warm!?!?!?
Old Mar 30, 2010 | 01:30 PM
james350's Avatar
Exclamation warrior wont start warm!?!?!?
hey guys,
picked up a 87 warrior 350 recently, and cant seem to get it to start once its warm. i only have a pull start untill i replace the start relay. i can pull start it and it usualy starts on the second or first pull, but after it warms up i cant seem to get it to pull or bump start. any ideas or similar problems???
thanks
Old Mar 30, 2010 | 01:46 PM
91Warrior357's Avatar
bad electrical components usually break down when they get warm, have you tried checking the spark on it? maybe compare the spark on a cold start then compare it when it wont run(warm).
Old Mar 30, 2010 | 02:14 PM
james350's Avatar
thanks!! while i was trying to do this i noticed that jiggling the cable that atteches to the stator defenetialy helped, starts every pull... thanks!
Old Mar 30, 2010 | 02:21 PM
ohh, yea the wires coming out of the side cover for the stator get worn, over time with all the wear and tear the wires get frayed and can cause problems with them getting wet and stuff, if i were you while the stator is still good (hopefully) take the side cover off(tilt the atv over and put buckets under the wheels so you dont gotta drain the oil lol) and re-wrap the stator wires really good with electrical tape and that might help, its very common for stators to poop out on warriors, it sucks.
Old Mar 30, 2010 | 02:26 PM
Snow Rider's Avatar
Is it just me, or do all Warrior electrical parts commonly poop out? I've only had problems with a starter and starter relays, but after reading all these Warrior problem threads the past few weeks.....
Old Mar 30, 2010 | 02:28 PM
no its true, definitely the weak spot for warriors.
Old Mar 31, 2010 | 03:10 PM
james350's Avatar
i took my entire stator assembly apart and re fixed the insalitation on the wires, however i noticed that one of the coil packs on the stator was burnt looking, and had lots of corrision on it. however i was still able to start the bike once after i fixed the insalitation, now it wont start at all. dose this mean its time for a new stator assembly?
Old Mar 31, 2010 | 06:37 PM
aww man it might be to late to save it then, you can perform an ohms test to see if its good or not, the specs for a good stator are in the manual, and if you need a new one order one from Rickys or RMStator, you can also go to there website or call them for help with testing a stator or any other questions.
Mkp
Mar 28, 2020 03:50 AM
chinkapin
Jul 14, 2016 06:58 AM
Nelson
Jun 20, 2015 01:59 PM
Jbird4681
Jun 9, 2015 01:59 AM
1000gade
May 27, 2015 12:37 PM
