atv winches
Old Apr 4, 2010 | 01:26 PM
BB'S700TWIN's Avatar
Default atv winches
Are all atv winches junk...Had a 2500 lb warn on my mule, and a 2500 lb polaris on my 550 xp.the warn broke the first time i used it, and i can say after yesterday the polaris was the same..
Old Apr 4, 2010 | 02:05 PM
I had a connector problem on one of our two Warn 2500 lb. winches. Other than that they sure have come in handy. I think one of the things that helps is using a ****** block pulley to help the winch to work a little easier. I also rev. the engines a bit so they are getting plenty of juice when winching. So far, other than the one problem they have been excellent.
Old Apr 4, 2010 | 02:06 PM
bentarrow's Avatar
First Things First!
I pulled down a 7 foot tall railroad tie retaining wall with my Warn 2500, strapped the rear hitch on the Polaris to a tree, blocked the tires and broke the cable but the Warn still works fine after 3 years. Only used the Polaris winch on the 850XP 1 time to move a tree off the trail with no problem.
Old Apr 21, 2010 | 03:09 PM
jevans's Avatar
i pulled a mini van out of the snow with mine.(2500) but i have a qestion for anyone. mine crapped the other day and i'm not sure whats wrong with it. is there a way to test it or the motor at least? i'm thinking it's the contactor. but i could not tell ya.
HELP DON'T WANT TO GET STUCK IN THE MUD
Old Apr 21, 2010 | 03:20 PM
DODGE57HEMI's Avatar
Mopar Man!
Warn for me without question! Tho I have heard good thing about these guys for a while now! Bulldog
Old Apr 21, 2010 | 04:25 PM
james feeney's Avatar
I had a 2000lb Warn on my 300TRX and it did plenty for the quad. I did however eventually burn out the solenoid. It was a basic winch without a contactor. Never did fix it yet it's still on there.
Have done a lot of competitive winching over here in 4x4 (not atv) competitions. It's all about speed. A friend of mine has just designed a high mount based around the principles of a Warn 8274-50. It is a brand new winch. Do you think I would need heavy duty springs on the quad with this on the front???
All the best
James
Old Apr 21, 2010 | 05:01 PM
Mopar Man!
This all depends on the ATV its going on LOL Nice!
Old Apr 21, 2010 | 06:31 PM
4getful2's Avatar
You have to look at what a winch is,just an electric motor with a spool and a couple of gears. from the winches i've seen,none of them are sealed from the elements and they all need a lil' maintenence from time to time. I go thru so much mud and water that i take mine apart in the spring every year to clean the crap out of it ,just to keep it working in both directions.
Old Apr 21, 2010 | 07:20 PM
Mopar Man!
The new Warn XT/RT line of winches are completely sealed!
Old Apr 22, 2010 | 05:47 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you can power directly too the winch to by pass the contact to see if it is working.
