Rolled my qaud in water.
Old Apr 5, 2010 | 06:06 PM
INDA605's Avatar
Unhappy Rolled my qaud in water.
I have ridden my Kodiak 450 (2005) into very deep water past the seat and headlights and never had trouble. I wanted to show my son how we ride the trails instead of letting him putts up and down the driveway, so I let him take it into the ditches, which were full of water, he was doing great but then he got nervous because he was getting pretty wet and he tried to ride out and did the no no, he rolled it completely over into the water. I was near him so I quickly turned it upright, pushed it home, changed the oil and pulled the spark plug. The air box was full of water also so i replaced the filter and dried it out real good. I cranked it over a few times without the spark plug in, to make sure we got all the water out and put it all back together. It starts right up idles great but it has no power. I tried to go up and down the driveway and I maxed out at 5mph then seemed like it was slipping! I don't know what to do! Please anyone, can you help me?
Old Apr 5, 2010 | 06:09 PM
Ledawg's Avatar
I suspect you have water in the belt case. Drain that and you should be fine. There is a plug at the bottom you pull and it will drain. Im kind of assuming that its like my Wolverine 450.
Old Apr 5, 2010 | 06:13 PM
INDA605's Avatar
I wouldn't even know where to begin looking for that plug. Is it a bolt or a plastic plug? I found another bolt head just behind the oil plug but i think that is for my trans. I do appreciate you quick response! Thanks!
Old Apr 5, 2010 | 06:52 PM
INDA605's Avatar
Thumbs up Rolled my qaud in water update.
I did finally locate the water drain plug it is near the right foot brake. I pulled it and what do you know about a gallon of water came out. the thing runs and rides great! thank you for your help!
Old Apr 5, 2010 | 06:54 PM
INDA605's Avatar
thanks dude. that was the whole problem
Old Apr 6, 2010 | 06:07 AM
Ledawg's Avatar
Smile plug
No problem. Sorry I didnt get back to you sooner. I just go the message. Im glad you found the problem. Everytime I ride I make pulling that plug part of my clean up. That way water never sets in there.
Old Apr 6, 2010 | 07:43 AM
CraZySteve's Avatar
Hey Inda,
I would also check the Front and Rear Diff's to see if any water got in their via the vent tubes. It is a simply check - pull the side fill plug and dip a q-tip into the hole - if it comes out with oil on it then you are good. If it comes out milky - then you got some water in their.
Also if you would like - I have a copy of the Service manual for 03-06 Kodiak 450's (Also good for 07-10 Grizzly 450's EXCEPT for the Rear Differential / Rear Wet Brake)
Email me directly @ snowwmax@yahoo.com
-CS-
fd24
Jan 16, 2019 08:59 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
1000gade
Sep 9, 2015 04:41 PM
Albertaboyy
Sep 9, 2015 09:51 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
