05 YFZ450 popping noise
Old Apr 13, 2010 | 07:43 PM
bped01's Avatar
Default 05 YFZ450 popping noise
Its a 05 yammah YFZ450 with alot of upgrades. But the probelm is every time i leave off the throttle it will start popping. Not sure what could be the promble, need some help.
Thanks
Old Apr 14, 2010 | 07:17 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
Welcome to the forums. What type of upgrades? I can tell you your getting to much air and not enough fuel. You may need to adjust the air/fuel mixture or re-jet depending on your upgrades.
Old Apr 14, 2010 | 10:26 PM
bped01's Avatar
It has an HMF full exhaust and has some motor work done to it. I order a gasket from the head to the pipe. But if thats not the promble i will try what you were re-jeting it. But thanks for the help and the welcome to the forums.
Old Apr 15, 2010 | 06:55 AM
Koopa's Avatar
I'm trying to understand what you are saying here but, you ordered a gasket from the head to the pipe? If that doughnut gasket as we always called it is causing an exhaust leak that will most definitely cause your problem. If it has a pipe on it hopefully it as been re-jeted.
Old Apr 15, 2010 | 09:02 PM
Scooter86's Avatar
Knows Old ATV Questions!
usually you can fix this by making the fuel screw richer and/or going up a bit on the pilot. Make sure you don't have any intake/exhaust leaks first though. mine would do this from an intermittent exhaust leak.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Alex G.
Sep 11, 2017 11:38 PM
mrtidy
Feb 3, 2016 05:00 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
Sep 23, 2015 06:23 AM
