Fuel Problem with 08 Trailboss
Old Apr 17, 2010 | 06:11 PM
RKBA's Avatar
Default Fuel Problem with 08 Trailboss
I have gas dumping all over the place! Any help would be apprecated.
'08 Trailboss with @400 miles on it. Only ridden a few times. Last time was over 9 months ago. Stored in the garage. I ran the tank dry before putting it away. Fast forward to today.... I filled the tank and charged the battery. It started right away. Let it idle for a minute and then shut it down and continued to charge for another hour. Went back and there was gas all over the floor. It was leaking out the small tube hanging below the frame. The tank was dry but there was not 2 gallons of fuel on the floor. Hmmmm. I popped the seat and opened the air box. It was FULL of gas. Ugh! Any ideas? I am good with cars but I have never really turned a wrench on one of these. Thoughts?
Old Apr 17, 2010 | 06:45 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. souns like the float is sticking wide open in the carb.you most likely will have to take the carb off and apart to see why its stuck open.
Old Apr 17, 2010 | 06:51 PM
dwyer83177's Avatar
sounds to me like the float in the carb is stuck,
Old Apr 17, 2010 | 07:26 PM
RKBA's Avatar
Thanks guys! That's what I thought. I've been working with Carbs since I was in high school and had many sticking floats over the years but never fuel flowing with the engine off................... Duh! Needless to say I've never turned a wrench on an ATV/Motorcycle............ Oh yeah, the tank is ABOVE the carb! Gravity? Boy do I feel stupid :-(
Thanks guys. I'll report back once I figure it out.
Old Apr 17, 2010 | 07:38 PM
Kerbbirds's Avatar
Probably dirt under the needle and seat ,which the float controls, may need a new needle and seat, chack the engine oil for gas, Ill bet its got some in it, after you get it fixed, turn the gas off when not in use and use Stabil when it sets awhile.
micheleLeigh
Jul 12, 2015 02:50 AM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
