need help older polaris 4x4
Old Apr 18, 2010 | 12:23 AM
jclape's Avatar
Default need help older polaris 4x4
i own a 94 polaris 300 went out for the first time this year and went muddin about 2 hours into the ride i started hearing like a screeching sound from the front of the wheeler so i stopped and greased up the front end where the chain hooks to fron assembly is all i get for a part name but i noticed when cleaning off that all the grease i pumped in was not where it should be inside the assembly it was all over the space behind where the chain cover is is it possible that it cracked i have not pulled it out yet wanted your opinions frist
Old Apr 18, 2010 | 05:25 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
maybe a bearing gone? any play in it?
Old Apr 18, 2010 | 12:03 PM
jclape's Avatar
i grabbed the u joint and shook it there was no play in it i kept regular greasing after every ride so iam at a loss
Old Apr 18, 2010 | 08:53 PM
Kerbbirds's Avatar
There are 2 bearings with a spacer between them in each essentric wich tighten the chains,might have one going ba.
Old Apr 18, 2010 | 09:19 PM
jclape's Avatar
y would all of the grease end up behind the ecentric and should i just replace the bearing i always made sure there was grease in those
Cole Hadden
Jun 15, 2025 09:05 AM
ghost civic
Jan 15, 2020 07:43 AM
NoJoke
Aug 9, 2015 12:39 PM
Geolorgist
Jul 26, 2015 09:48 AM
