torque specs for 1999 Polaris 500
Old Apr 21, 2010 | 07:51 PM
clint wilson's Avatar
Default torque specs for 1999 Polaris 500
Hello . Thanks for the last reply. Does anybody have the torque specs for cyl and head bolts on a 99 polaris 500 sportsman. and valve clearance. Thanks for any replies.
Old Apr 21, 2010 | 08:59 PM
Pous's Avatar
If im not mistaken the valve clearance on the 500s should be .006 on both intake and exhaust. Im not aware of the torque specs though
Old Apr 21, 2010 | 09:47 PM
ctdnwakulla's Avatar
My manual only covers up to 98 and according to it .006 for the valves is correct. The cylinder torque, again for 98, is 46 ft/lbs for the 10mm bolts and 6 ft/lbs for the 6mm bolts. The cylinder head torque procedure is as follows; 22 ft/lbs, 51 ft/lbs, loosen evenly 180 degrees, then loosen an additional 180 degrees, torque 11 ft/lbs, then tighten 90 degrees then another 90 degrees. Install 6mm bolts and torque to 6 ft/lbs. You got that, sounds like some of the vehicles we have worked on LOL.
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Unzzy66
Jul 11, 2015 10:01 PM
RedRancher
Jul 10, 2015 06:36 PM
