2007 700 EFI trans problem
Old Apr 25, 2010 | 06:31 PM
dannyrscott's Avatar
Default 2007 700 EFI trans problem
got me a problem Its a 2007 sportsman 700EFI and when im in neutral, low or high gear it reads N on the gear indicater. It had a very bad clunking and shuttering while under some load (going up hill or driving with brakes on) in either high gear or low gear. So i got code 25 (Transmission Input - Invalid Gear). So Im gonna check all the electrical connections and if that doesnt fix it replace either the little computer chip thing or the gear selecter? Is the clunking caused from the computer thinking its in neutral?
Old Apr 25, 2010 | 06:36 PM
Sounds like gear switch on trans is bad,giving false gear inputs on speedo,which in turn can cause running problems. OPT
Old Apr 25, 2010 | 08:06 PM
UTU's Avatar
UTU
Thumbs up Bad gear electric switch
I agree,had 2 replace a few!!!
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
Sjrpp
Jul 5, 2015 09:04 PM
