Old Polaris Tech Need Help w/ Code 54
Old May 9, 2010 | 06:44 AM
tbg120's Avatar
Default Old Polaris Tech Need Help w/ Code 54
I was hoping I could get some help. I am working on a 2005 700 EFI throwing a code 54. There is no troubleshooting help in my repair manual specifically concerning this code. I have tested the coolant sensor and swapped out speedometer heads. The Polaris tech's around here have never run into this code before.
Thanks in advance.
Old May 9, 2010 | 08:07 AM
TLC's Avatar
TLC
Whats code 54 mean,wheel falling off,over heating or what?
Old May 9, 2010 | 08:16 AM
JCDEYO25's Avatar
My service manual says it has to do with the engine temp lamp...open load,short circuit to ground, or short circuit to battery...
John
Old May 9, 2010 | 08:21 AM
TLC's Avatar
TLC
So the ATV is running OK . I has a "check engine" light lit for 4 years a 96 F-150 that ran like a top ,the bulb finally burnt out one day. LOL
Old May 10, 2010 | 06:34 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
John
Grounding issue
Old May 10, 2010 | 07:44 PM
tbg120's Avatar
"Grounding issue"
Got any more info? Where should I start looking etc....
Old May 11, 2010 | 07:12 AM
Kerbbirds's Avatar
Clean the connections at the battery, have heard of some even being loose, then work your way up the wires from there.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
TheHood
Jul 26, 2015 09:51 AM
maxjung
Jul 23, 2015 08:37 PM
