clutch engaging in idle
Old May 9, 2010 | 11:49 PM
BigRawJ's Avatar
Default clutch engaging in idle
Every once in a while my bike will want to move in whatever gear im in at idle. The idle speed is set properly. Is this something I can adjust or is the clutch spring getting lazy?
2002 Sportsman 500
Old May 10, 2010 | 06:36 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Crush washer on primary clutch is worn out, if you have the tools to break down a primary clutch, separate sheaves, crush washer is on the non-moveable side.
Old May 10, 2010 | 03:57 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
either that on the ebs busing is bad and you need a spider tool to fix either one.
Old May 10, 2010 | 08:35 PM
BigRawJ's Avatar
thanks ill look into it. Do you guys know exactlly what tool I need to take the front clutch off?
Old May 11, 2010 | 03:34 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
taking the clutch off is actually the easy part w/ a clutch puller or a 3/4" fine thread bolt(8 or 9") it's taking the spider apart where you need the expensive special tool.
Cummins Driver
Sep 11, 2019 01:22 PM
Mikesohio
Jul 26, 2015 10:51 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
ghost civic
Jul 15, 2015 10:48 PM
clsharky
Jul 13, 2015 02:07 PM
