1997 Polaris Trailboss won't hold charge
My 1997 Polaris Trailboss won't hold charge. Being the Battery is about a year old I thought replacing it would help. I filled the acid and trickled charged the batter according the battery instruction. The charger showed full charge. The quad started right up with the new battery using the electric start. I then removed the key. However, when I left the battery connected for a day, the starter just clicked. If I pull start, it starts right up and the light come on fine. I have checked the charging system and it is charging fine. If I disconnect the battery and connect it to jumper cables to my truck, it starts up fine again. I can leave the + terminal disconnected from the battery and connect it just before I start riding, but that doesn't fix the problem.
Please help.
Mark
Please help.
Mark
When the + terminal is disconnected from the battery the battery stays charged. When I connect the battery to the terminals, even when the ATV is off, it kills the battery. It almost sounds like there is a short in the electrical system, but then again, I can pull start it and when the battery is charged, the electric start starts it right up.
Mark
Mark
PS. Most multimeters will self destruct if you put more than maybe 10A thru them. DO NOT start the bike connected like this!
bzdok1234
30
Feb 23, 2016 01:55 PM
