2007 E-Ton Viper 70 4-cycle
Old Jun 22, 2010 | 01:01 PM
mcgougan's Avatar
Default 2007 E-Ton Viper 70 4-cycle
We've been having a problem lately with my sons viper 70. The slide inside the carb doesnt open at all on it's own. If I lift it with a screewdriver the motor will rev up ok but otherwise it runs slowly and quickly dies. I tore the carb apart to clean it and decided I'd go ahead and just do a full new carb kit including new slide. I still have the same problem after putting it all together again. Any advice is appreciated.
Old Jun 23, 2010 | 09:23 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
The slide not raising eh..
Going on what you reported::
First thing I think of is the throttle cable not moving correct (needs lube or new) or maybe the cable adjustment, or maybe there is a problem at the thumb throttle.
Let's go fronm there.
Maybe others will chime in.
Old Jun 23, 2010 | 10:27 AM
mcgougan's Avatar
Thanks LT80. The slide is not operated by a cable though. The throttle cable connects on the side of the carb and it does open the butterfly properly. It appears the slide should be opening by a vacumn somehow. The diagrapm is new, no tears.
Old Jun 23, 2010 | 12:47 PM
LT80's Avatar
LT80 Expert
Sorry, Not that familiar with the 4 strokes
My rancher has the same workings as yours. It seemed on mine that it raised with the engine rpm's. I agree, it would seem to be operated by vaccum...
Would you happen to be from Ireland?
flyin-lowe
Dec 1, 2017 03:18 AM
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
