00 Xplorer loose front bearing
Old Jun 29, 2010 | 10:06 AM
kelpaso's Avatar
Default 00 Xplorer loose front bearing
I replaced the hub and axle taper bearings and races. Upon assembly I noticed the whole hub was still loose. I took it apart to inspect it and what is loose is where the outer races are pressed into the strut housing and the magnetic pole presses onto the strut. The whole magnet and bearing races wiggle around. Looking at the parts diagram I am assuming the strut is broken behind the magnet. Anybody else seen this? It looks like I need to replace the whole strut assembly.
Thanks
Kel
Ean
Dec 19, 2022 08:48 AM
JackTheKing
Jul 14, 2015 09:09 PM
clsharky
Jul 13, 2015 02:07 PM
tporath
Jul 11, 2015 12:31 PM
cornermike
Jul 8, 2015 11:44 PM
