View Poll Results: Do you set the brake when towing or just leave it in Park?
I set the brake
16
76.19%
I put it in Park and let the straps do their work
23.81%
Voters: 21. You may not vote on this poll
Set the brake when towing?
Old Jun 29, 2010 | 05:54 PM
OffRoaded's Avatar
Question Set the brake when towing?
Do you set the brake when you tow your Polaris or just leave it in park? I read somewhere (maybe the manual?) that the brake cable will get stretched out after 10 minutes or so and the brake would be useless at that point... but I don't know if that was implying that I shouldn't set the brake when towing, or if it was just talking about general riding conditions.
Suggestions?
Old Jun 29, 2010 | 06:08 PM
Mongrol's Avatar
"Official Site Skeptic"
Depends on the machine, most newer ones have hyd. brakes & no cable.
Old Jun 29, 2010 | 06:26 PM
OffRoaded's Avatar
That wasn't an answer I was expecting... Kind of invalidates the whole poll. I've got two 2010 550's - an X2 and an XP... so I assume based on your statement that I should have hydrolics. I'll double check, but I thought it was my manual telling me not to do that though.
Old Jun 29, 2010 | 06:32 PM
Mongrol's Avatar
Both are Hydralic.
Old Jun 29, 2010 | 06:45 PM
OffRoaded's Avatar
Thumbs up I checked and...
You're absolutely correct - both are hydraulic, and there's no mention of leaving them engaged for extended periods. I must have picked that up from the boards, and I have no doubt that it was in reference to a model that had a brake cable.
Old Jun 29, 2010 | 06:47 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Polaris has been hydraulic front and rear for quite a few years now. I can't even remember how far back you have to go to see cable brakes if ever on the sportsman's. I always set my brakes along with the park when towing.
Old Jun 29, 2010 | 06:49 PM
Mongrol's Avatar
Don't leave them on over night. Sometimes get a little spongy.
Old Jun 29, 2010 | 07:58 PM
switzomatic's Avatar
If I don't have mine wedged between two others or pulling solo I always set it.
Old Jun 29, 2010 | 10:56 PM
user493's Avatar
Moto Psycho
I put it in park, set the brake, and tie it down.
Old Jun 30, 2010 | 07:03 AM
EastCoastWest's Avatar
Luckily I don't have to worry about towing, I access all the trails I could ever want from my back yard. The owner's manual for my x2 says to lock the brake, like mentioned above I wouldn't leave it set any longer than it need to be, you could actually blow the seals in the cylinders.
