grips
Old Jul 4, 2010 | 12:15 PM
james feeney's Avatar
Default grips
Any tips or tricks for getting the rubber grips off the handlebars??
Thanks
James
Old Jul 4, 2010 | 01:38 PM
Kerbbirds's Avatar
put your air blower on your air hose from an air compressor plug the hole on one grip, put the blower in the other one, and push air through it, do the same for the other side only you need to put your hand over the tube of the handlebar
Old Jul 4, 2010 | 01:42 PM
Cut them lenghtwise, use a hot hair dryer on them to melt the glue, pull them off...
Old Jul 4, 2010 | 11:14 PM
rkuhnjr's Avatar
Then get yourself a pair of Odi Grips that do not use glue
Old Jul 5, 2010 | 08:51 AM
ftwflh's Avatar
DITTO on the compressed air..................IT really works
Old Jul 6, 2010 | 10:01 AM
09 popo HO's Avatar
X3 on the air compressor.
I stuck it in between the bars and grip where they meet the throttle or light switch and pull the trigger at the same time as you pull the grip off. Took less then a minute to get both sides off.
I did this when installing heated elements under the grips. This way I could re use the grips instead of cutting them off.
Old Jul 6, 2010 | 11:56 PM
chuck_raduenz's Avatar
there is no glue holding them on. x4 on the air.
black_thunder
Sep 7, 2015 01:24 AM
erntee61
Aug 9, 2015 02:54 PM
Stirling
Aug 9, 2015 01:49 PM
Scottma518
Jul 10, 2015 12:42 AM
ScoobyDFW
Feb 3, 2000 11:58 PM
