I changed the starter Polaris trail boss 1998
Old Jul 13, 2010 | 06:57 PM
taximan's Avatar
Default I changed the starter Polaris on a trail boss 1998
I changed the starter on a Polaris trail boss 1998 and still the same thing click click, what could it be the clicking is not coming from the starter it sound like it is near the battery
Old Jul 13, 2010 | 07:34 PM
The Kid's Avatar
starter silinode. i cant spell it but thats your problem
Old Jul 13, 2010 | 07:57 PM
taximan's Avatar
where is the solenoid
Old Jul 13, 2010 | 08:16 PM
taximan's Avatar
i think i found it i will give this a try
Old Jul 14, 2010 | 05:42 AM
The Kid's Avatar
it is by the battery
Old Jul 14, 2010 | 08:28 AM
dawgsfan's Avatar
Taximan how hard was it to change out the starter yourself?
Old Jul 14, 2010 | 03:40 PM
taximan's Avatar
very hard i had to set it straight up in the air on the back tires to get the top bolt off the starter, i had to cut a 10mm socket and drill a hole through it so i could stick a screw driver in the socket so i could turn the bolt , i was not comfortable trying to remove the clutch so i chose to do it that way, it wont be so hard the next time because now i know how to get it off
Old Jul 16, 2010 | 02:21 PM
kilted-rider's Avatar
Default The Dreaded Click
When you removed the starter, did you check the starter pinion? It causes the dreaded click when it corrodes and will not freely engage.
Old Jul 16, 2010 | 08:19 PM
taximan's Avatar
i changed the solenoid and it starts and will run as longs as i hold the trottle but as soon as i let it go it cuts off, not i need to get it to idle, any sugestions
merryman
Jun 15, 2015 02:36 AM
clsharky
Jun 8, 2015 11:38 AM
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
