2007 500 EFI starting problem
Old Jul 23, 2010 | 08:16 PM
mstarling's Avatar
Default 2007 500 EFI starting problem
Guys,
I have been having starting problems with a 2007 EFI Sportman 500 since the late winter. It has 131 miles on it ... so is not old. Was outside more than it should have been. (Battery has been replaced and is on a battery tender.)
I have disconnected each of the connectors I can reach, cleaned them, and replaced the dielectric grease.
Symptoms:
1) Sounds different when the key is turned in 4WD and 2WD. In 4WD it makes a low hum (I think that is the fuel pump). In 2WD it makes that hum for some seconds and then the injectors click and it goes back to the low hum.
2) Console does not light (show any numbers) while this is going on.
3) If I run 5 to 10 second bursts of the key on with the switch in 4WD maybe five times, then switch to 2WD ... the console will sometimes light and act normally. If that happens, the bike starts immediately and runs fine!
4) If it has started, it will restart relatively easily for a while. The longer it goes, the less likely it is to start.
Guys ... I REALLY need some help here. I can't afford to take this thing to the dealer and get hit with a $1,000 bill to fix it!!!
Would sure appreciate your thoughts!
Mike
Old Jul 24, 2010 | 09:56 AM
TLC's Avatar
TLC
Is your ATV on the electronic control modules (ECM) recall list,That brain box controlls more things then it should.
Old Jul 24, 2010 | 09:59 AM
x2 bum's Avatar
how do you find out if your machine is on the list?
Old Jul 24, 2010 | 10:01 AM
TLC's Avatar
TLC
Just google " Polaris ATV Recalls" and look around.
Old Jul 24, 2010 | 10:47 AM
mstarling's Avatar
My 2007 EFI Sportman 500 is not on the recall list.
Mike
Old Jul 24, 2010 | 12:22 PM
x2 bum's Avatar
I did a lot of searching. I did not find any recalls on the 2007 500 ho x2. I read many complaints about the Polaris's realiablity issues and problems. I bought used with only 30 miles. I put another 50 the first weekend with no issues. Wife will kill me if I have to put a ton of money into maintenance. I ride DS on a honda xr650l. I am spoiled with low maintenace and bulletproof.
Old Jul 24, 2010 | 01:20 PM
Sportsmanhunter's Avatar
I have a '04 polaris sportsman 500 HO and i know that if my speedo is not plugged in the whole way it should be, the machine will die right after you start it and it will not run right at all.....also, the 4 wd will not work.....Hoipe this helps......
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
