my warrior has no spark
Old Aug 11, 2010 | 10:54 AM
kevinzebra's Avatar
Default my warrior has no spark
i have a 2001 warrior engine and a 2003 harness i have the essentials like the cdi the voltage regulator the starter relay the ignition coil but when i hook up the positive and negative to try to start it, it wont give spark. any help would be great thanks
Old Aug 12, 2010 | 09:27 AM
hillbilly_racer's Avatar
The stators on the Warriors were notorious for going bad. Test the stator and the pick-up coil and make sure they are both good.
Old Aug 13, 2010 | 02:57 PM
kevinzebra's Avatar
pick up coil as in ignition coil?
Old Aug 16, 2010 | 03:27 PM
No, the pick up coil is down with the stator behind the flywheel on the left side of the motor.
Old Aug 16, 2010 | 06:43 PM
kevinzebra's Avatar
it should be inside the motor or outside, sorry im new to this
Old Aug 22, 2010 | 09:23 PM
drstiddy's Avatar
it is inside the motor...left side of motor has a harness coming out. part of those wires are to it. theres a way to check both with a voltmeter set on ohms for resistance. more than likely that is it.
Old Aug 22, 2010 | 10:18 PM
kevinzebra's Avatar
tthanks for the info
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
