99-04 Bear Tracker Carb Kit?
Old Aug 13, 2010 | 10:03 PM
Sgt_Morrow's Avatar
Default 99-04 Bear Tracker Carb Kit?
Just bought a new carb kit for my 99 Bear Tracker everything going good except I cant figure out where this ginat O-Ring goes? Anybody ever Rebuild one of these before. Same carb they put on a 350 Big Bear.
http://i998.photobucket.com/albums/a...kerCarbKit.jpg
Old Aug 14, 2010 | 12:34 AM
HeftyLefty's Avatar
That O-ring goes around the top of the float bowl to keep the gas from sloshing out. There will be a groove either on the top of the float assembly the bowl mounts to , or on the top edge of the bowl itself.
Look carefully, with a bright light , you should see it. Carefully remove the old O-ring , and install the new one. I would take a Q-tip and dab a little Permatex # 2 on the groove to help the O-ring slide in and seal. Use the other end of the Q-tip to work the new ring into the groove. Be very patient, if you nick or break the O-ring, it will have to be replaced.
Make sure the carb vent tubes are unobstructed, kinked, or pinched during reassembly.
Old Aug 14, 2010 | 09:48 AM
Sgt_Morrow's Avatar
The float bowl has a square gasket. This is a big round gasket just like in the pic. I dont think it is used for the float bowl.
Old Aug 14, 2010 | 10:13 PM
papa hogg scoot's Avatar
Loved
Community Favorite
If your bowl is paper than this wont fit IMO.But if its is rubber than it will replaced your old gasket,these aftermarket parts are not indeniall to oem,in order to sell parts at an cheaper price.for instance this kit,they cant have an mold to shape these oring like the oem one so they use this type oring But IMO this has always work for me.. just hold this oring over the old bowl gasket while the old one is still inside the groove and shape it around an see if it will fit..If not...is your old one still good? if so than reuse it....Good Luck... keep us all updated please.....
Old Aug 15, 2010 | 09:22 AM
Loved
Community Favorite
PS.If new oring will fit then like other said above remove old one than install new one...
Old Aug 15, 2010 | 09:38 AM
TLC's Avatar
TLC
My quess is you just stuff the O ring in the bowl grooveand it forms the shape needed.
Ean
Dec 19, 2022 08:48 AM
clsharky
Jul 13, 2015 02:07 PM
micheleLeigh
Jul 12, 2015 02:50 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
