new here...need some help
Old Aug 19, 2010 | 09:11 AM
2000xplorer's Avatar
Default new here...need some help
im 100% new to quads and 2 strokes but not new to turning wrenches on vehicles.
Anyways I just picked up a 2000 Xplorer 400 and I dumped the quad in water drained everything that had a drain plug and it started up but didnt move so i drained the PVT now everything is well, but I have no idea what i drained the pull start housing or the crankcase housing? is there supposed to be oil at the bottom of the crankcase or does the "2 stroke" lubricate the bottom end?
is there anything else i should check/change before i ride the quad hard again?
thanks
Old Aug 19, 2010 | 09:19 AM
TLC's Avatar
TLC
There is a drain plug below the recoil pull start housing, also drain the air box,front diff,there chain drive on the back right? There also is oil for the counter balancer it only takes a few onces. Might want to change the oil in the oil injection tank if it go contaminated.
Old Aug 19, 2010 | 09:21 AM
jetmecanic's Avatar
You just drained the starter housing. No crankcase oil in the 400. Grease everything and CHECK THE OIL IN COUNTERBALANCER!!!! Most critical on the 400. Also use a good synthetic two stroke oil and you will save your wallet in the long run. Good luck and welcome!!!
Old Aug 19, 2010 | 09:42 AM
where is the counter balance and what does the counter balancer do?
Old Aug 19, 2010 | 10:50 AM
also if the counter balance fluid is empty or very dirty how much damage has that done to the engine if run hard?
Old Aug 19, 2010 | 10:54 AM
DODGE57HEMI's Avatar
Mopar Man!
Welcome!
Old Aug 19, 2010 | 11:16 AM
im going to take a picture of the drain plug i pulled and then get you guys to verify if its the starter housing or the counter balancer.
Old Aug 19, 2010 | 04:47 PM
so here is plug i drained. what is it? counter balance or starter housing?
and is this my counter balance fill plug? the slotted plug way at the bottom? if so where is my drain plug? in relation to the above plug in the above photo?
thanks
Old Aug 20, 2010 | 01:01 PM
Wenty's Avatar
Your owners manual has all this info in it...if you don't have one go to the polaris site, they have them in PDF.
Polaris ATV, RANGER, Snowmobiles, Victory Motorcycles Website
Bottom of page (riders guide) and (manuals and parts). You'll have to sign in, quick and painless. Download the manual, it should answer all your questions.
Yes, the slotted plug is your counter balance fill...the drain is under the skid plate, along with the crankcase, recoil and starter drain.
Wenty
Old Aug 20, 2010 | 05:29 PM
Overdrive's Avatar
The plug you have in the red square is another way to check the counter balance oil. The oil level should be even with that plug just like the manual trans on older cars and trucks.
This oil is VERY VERY important on the 400 engine. If the counter balancer goes it will destroy the entire engine. It WILL go out if it is run without oil or it gets full of water.
It will also last forever as long as it is full of good clean oil. Check it often.
