new here...need some help
Old Aug 20, 2010 | 06:51 PM
2000xplorer's Avatar
okay when i drained that plug in the red square alot of water came out, and we ran it for maybe 10 mins but throttling it up and down to dry my PVT.
how much damage do you think is done? and i fill it using the slotted dipstick hole?
and what drain plug is that in the green circle? i opened that and oily THICK goo came out is that my counter balance drain plug?
PS i checked for a manual on the Polaris site and its unavailable, so i have one on order at the dealership.
Old Aug 20, 2010 | 08:06 PM
ftwflh's Avatar
Fill it with 10w30 oil run check drain repaet until it is clear oil.KEEP AN eye on this or your 400 will be toast
Old Aug 21, 2010 | 12:26 PM
So the green circle is counter balancer drain plug?
Old Aug 22, 2010 | 08:10 PM
anyone know?
Old Aug 23, 2010 | 09:59 PM
  #15
well i filled it up and un did the bolt in the green circle nothing came out, then i undid the bolt in the red box and oil came out, so the oil should be level with the bolt in the red box right?
Bowtechhunter
Feb 1, 2013 08:14 PM
