06 450 sportsman help
Old Aug 20, 2010 | 01:02 PM
Ribbons's Avatar
Default 06 450 sportsman help
Im having a problem with my 450. When i start the wheeler my gauges flash "check engine", and "HOT". The motor is not hot, and it has coolant. I just replaced the battery and pulled the thermostat with no changes to the condition.
Any suggestions on the next logical step or if anyone has had similar problem? Thanks in advance.
Old Aug 20, 2010 | 05:21 PM
Overdrive's Avatar
ECM malfunction or temp sensor malfunction.
Old Aug 20, 2010 | 05:48 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. i would check w/ a dealer to run your vin# as there was a recall for for bad ecm's on the 450's. i agree it sounds like a bad ecm.
Old Aug 23, 2010 | 10:21 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Yes ......Sounds like ECM issues if the Quad is COLD and Flashing "HOT"
I am on my third on my Quad.......And just the re-call replacement for the Wife's.................Caper........
Old Aug 23, 2010 | 04:50 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you check w/ the dealer with your vin# yet?
Old Aug 23, 2010 | 10:07 PM
Ribbons's Avatar
Thanks for the help and the welcome. I did check with the dealer, it is a recall and it looks like they are going to replace it for me. Im glad i didnt just buy a new one!
Old Aug 24, 2010 | 01:39 AM
TLC's Avatar
TLC
Glad you found the ECM trouble out.
Old Aug 24, 2010 | 09:08 AM
MrMarty51's Avatar
Before they install that new ECM have "Them" remove the cover and make sure it is not full of moisture and corossion,When they replace My ECM it was all corodded up inside and did`nt last a year and I had to foot the bill for a new one.That really sucked.
Old Aug 24, 2010 | 10:25 AM
It they do the job it should have been there fault???
I put one in myself and the dealer did one...........Remember it comes with a small pack of Di-electric Grease This needs to be used and not thrown out with the box!!
This helps the connectors with moisture and thus corrosion. If you do it use it.....................If the dealer does it ask it they used it?
Caper..................
Old Aug 24, 2010 | 12:17 PM
Ribbons's Avatar
What if they do find corosion inside? I asked the dealer if i could just get the part from him and put it on myself, but he said due to the nature of the recall he had to install it.
