99 scrambler clutch, ect?
Old Aug 23, 2010 | 08:48 PM
polcat1p's Avatar
Default 99 scrambler clutch, ect?
how does the clutch come off the crank? i took the bolt off, and it does not want to budge. do i need a puller? Also i just bought this bike cheap ,and was told the crank seized. i started to take things apart, like the exhaust. when i did i noticed chunks of metal in the first bend off the exhaust. could it be a piston? hope its not botttom and top end. the engine will not turn. where can i download a manual?
thanks
1990 scrambler 400 4x4
Old Aug 23, 2010 | 09:00 PM
Overdrive's Avatar
You need a puller
Old Aug 23, 2010 | 09:19 PM
ftwflh's Avatar
yep piston skirt let go
Old Aug 23, 2010 | 09:36 PM
polcat1p's Avatar
do you think my bottom end is messed up too?
Old Aug 23, 2010 | 09:39 PM
Big-O's Avatar
Watch this it shows you how to pull clutch
YouTube - Polaris Sportsman EPI Clutch Kit Install - Part 1 of 4
Old Aug 24, 2010 | 04:44 AM
polcat1p's Avatar
if my crank is good, whats the easest way to get all the metal out of the bottome end? do i still need to take the clutch off and get at the case from there?
thanks
Old Aug 24, 2010 | 05:55 AM
ftwflh's Avatar
thanks
Easiest way to get the metal out is split the cases.You have to have a puller to get the clutch off and it must come off.
If you are lucky it didnt take the cases out with the piston.If it did drop me a PM I have a spare 400 engine.
Old Aug 24, 2010 | 07:49 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
If you can't turn the motor over, you have piston pieces in your crank journals. Best advice is to tear down the motor, pull crank and counter balancer and have inspected. Crank bearings will need to be carefully gone through to make sure there are no piston remains. Counter Balancer with any grooving on the end of the shaft is junk.
Old Aug 24, 2010 | 10:11 AM
TLC's Avatar
TLC
Nice link, thanks.
Old Aug 24, 2010 | 04:39 PM
polcat1p's Avatar
thanks guys. my local polaris shop pulled my clutch for me, so i will try and pull the engine in a day or 2. this is just my luck. just when i think i get a good deal on something. oh well maybe it wont be that bad. i post pics of the parts when i get it apart.
thanks again
