02 Sports 700 overheating
Old Aug 24, 2010 | 12:59 PM
97xplorer's Avatar
Default 02 Sports 700 overheating
I have a problem with a 02 sportsman 700. It want to overheat within 10-15 min of riding. The radiator appears to be clean and can see through it. I put anti freeze in it, and within a week you can tell that some has disappeared. There are no puddles of anti freeze anywhere.
What do you think?
Old Aug 24, 2010 | 01:18 PM
02magnum500's Avatar
Gets his share of deer.
Must be a head gasket and you are burning the coolant. They do get hot when a head gasket is out I think. Just my 2 cents.
Old Aug 24, 2010 | 02:08 PM
97xplorer's Avatar
any symptoms of a bad head gasket?
Old Aug 24, 2010 | 02:11 PM
white smoke out the exhaust. Exhaust may have a sweet smell to it at a distance. Notice any of these?
Old Aug 24, 2010 | 02:18 PM
97xplorer's Avatar
hate to say it, but no. and the water pump is working.
Old Aug 24, 2010 | 02:21 PM
How fast does the coolant get removed ?
Old Aug 24, 2010 | 02:51 PM
97xplorer's Avatar
never notcied the amount, just that the rad goes empty along with the res.
Old Aug 24, 2010 | 07:44 PM
Try filling the radiator,leave the cap off while running at idle,add fluid as needed,when fan kicks on a lot of air is removed and level usually drops,keep topping off radiator and let fan cycle on and off several times,replace cap, top off coolant bottle and then ride and see if ok. Any air at all in the system will cause it to bubble out coolant bottle and can cause problems. Just food for thought! OPT
Old Aug 25, 2010 | 08:53 PM
Big600twin's Avatar
check the oil dipstick to see if it is just oil or if there is coolant mixing. I had the oil seal and water pump seal go bad and that was causing the machine to lose coolant and overheat but it did not get burned out the exhaust like a bad head gasket.
Old Aug 31, 2010 | 12:05 AM
bsan1827's Avatar
Your water pump seal could be going, it happened on mine about a year and a half ago. you will lose a little coolant at a time look under the bike at idle on the right side just in front of the foot brake
