98 magnum 425 cooling system
Old Aug 31, 2010 | 08:24 PM
jbuch2002's Avatar
Default 98 magnum 425 cooling system
I have a 1998 magnum 425 and it keep pushing coolant into the over flow tank enough to leak out the vent cap and on the ground after it cools sucks the over flow just about empty and the cooling fan is coming on have checked for an air lock by cracking the tstat housing loose no air lock anyone no of any problem issues?
Old Aug 31, 2010 | 08:30 PM
Overdrive's Avatar
The Rad. cap could be bad. Don't give Polaris $35 for one. You can get one at any auto parts store for about $6 to $8.
Old Sep 1, 2010 | 12:25 AM
TLC's Avatar
TLC
Maybe bad rad cap not keeping its psi, the way to check for air lock,its to grab top hose and bottom hose.
If top hose is hard and hot, but bottom Rad hose is soft and cool ,you need to Burp/Bleed the air out of the coolant system.
Old Sep 1, 2010 | 07:08 AM
ftwflh's Avatar
If cap dont fix it chances are you have a bad head gasket
Old Sep 1, 2010 | 07:18 AM
jbuch2002's Avatar
Thanks for the info I have tried to purge air but there was none in system rad cap good idea no external leak from head gasket and oil is clean just wondering if any one has ran into a thermostat or water pump issue
Old Sep 1, 2010 | 09:03 AM
ftwflh's Avatar
The nut on the water pump has been known to back off and thermostat can go bad too.
Gwolf228
Feb 18, 2017 01:36 AM
Oct 10, 2015 10:20 AM
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
