27x12x12
I'm running 8 x 12 x 27 bugs on the fronts and there's not enough space between the tire and tie rod end to put my finger in, you'll need at least a 2" spacer on the front or aftermarket wheels with more offset. You won't have any problem with the rears, your best bet is to resell two of them and buy 2 8" tires for the front. Anything wider will make it harder to steer in awd.
