bogs out and stalls and full throttle
i have a 95 xplorer 400 4x4 the other day i was riding around going thru puddles and stuff when all of a sudden i had no throttle whats so ever so being stuck in the woods i took my seat off and took the cap off the carb that the trottle cable goes into the sleeve and put it back on now i have throttle again so i left to go home and as im riding the throttle got stuck i did the same thing and it stopped so yesterday i adjust the cable where it goes into the cap cuz i looked around on the net and to add ever since i got the quad it had a rough idle but anyway ppl said to turn it till you get a smoath idle so i did i also screwed around with the screw with the spring on the side of the carb and it seemed to be fine so i went for a ride everything going good until about 2 miles in and the when pushed the throttle all the way in started to bog and then stall i left of the throttle before it would stall and i got power right back so i figured it was something i screwed with on the carb so i need help i shouldnt have touch anything since i dont know anything about carbs so can any help me adujust my carb right i need put into simple step by step instuction
