Polaris 400L tools wanted...
Old Sep 2, 2010 | 12:01 PM
HydraulicKnight's Avatar
Default Polaris 400L tools wanted...
I'm looking for some old Polaris tools for a 400L motor. Specifically, I'm wanting the special socket that removes the reverse thread nut behind the stator. I need to pull the counter balancer for a rebuild. I may be interested in other tools also. I also may be interested in a scrambler 400 to use as a parts bike. Just let me know what you have. Thanks.
Old Sep 6, 2010 | 02:32 PM
marc2000gt's Avatar
I just replaced the seals and bearing behind the water pump on my Sport 400. I removed the nut with a brass punch.
Old Sep 10, 2010 | 09:05 AM
Yeah I was able to remove the nut with a thin file and a hammer. I pulled the counter balancer and crank gear with a slide hammer and a 6mm bolt. All in all the flywheel was the hardest to remove, i broke a puller trying, that was before i relized to beat on it with a hammer. Thanks for the reply though.
Old Sep 10, 2010 | 09:10 AM
94harley's Avatar
Carefull beating on flywheels with hammers. You can break or dislodge the magnets and if that happens and you run the machine you can ruin and stator. Flywheels and stators are pretty expensive too.
Old Sep 10, 2010 | 09:26 AM
I was somewhat carefull. The first try, before I broke the puller, I stripped half the threads out of one of the holes in the flywheel because I didn't have the bolt threaded enough. Then the puller broke. So the last try I beat on the puller shaft with a rubber mallet and it popped right off.
If CB oil is burning out my exhaust is my crank seal bad? My water pump seals and bearing were shot, but my crank bearings and CB bearings feel fine. The crank oil seal also "looks" ok. The CB oil is a rusty red color.
Old Sep 10, 2010 | 06:06 PM
marc2000gt's Avatar
If a hammer won't fix it, its an electrical problem.
Old Sep 10, 2010 | 08:16 PM
Words to live by!! OPT
Cole Hadden
Jun 15, 2025 09:05 AM
Schneider
Jul 24, 2015 05:05 PM
toonces
Jul 23, 2015 02:21 PM
toonces
Jul 21, 2015 02:40 AM
maxjung
Jul 13, 2015 05:11 PM
