Mojave Shocks
Old Mar 5, 2001 | 10:04 PM
MikeyM1980's Avatar
My rear shock is shot and was going to get it fixed when I checked out some other model shocks on ebay and would probably end up paying the same for one fixed shock as I would for three used in good shape shocks. The problem is will it fit on my quad. Can someone give me a little list on what will fit with no mods, little mods, and/or extensive mods? I found a front and rear set of shocks off of a 2000 Banshee for $150. I'm sure the front will fit but since the rear shock is linked to the banshee swingarm I'm not sure. If anyone can help or has attempted to use any other model shocks e-mail me. Thanks
Old Mar 5, 2001 | 11:09 PM
01MXBLASTER's Avatar
im pretty sure a tecate shock will work
Old Mar 6, 2001 | 02:18 PM
Lurch's Avatar
Dude, I have a set of shocks I pulled off of my 2000 Kawasaki Mojave. You want them??
Old Mar 6, 2001 | 05:21 PM
JD250R's Avatar
A rear shock off a 86-89 Honda TRX250R will work with a little tweaking. All you have to do is grind off the spacers on the Mojave's swingarm. This works great and is fairly inexpensive.
Old Mar 6, 2001 | 05:55 PM
Mxracer98's Avatar
Lurch when you put those handlebars on your Mojave did you need to use on a diffrent clutch cable? Because I put longer bars(RENTHAL) on my Mojave and and I need to know what the best cable to use would be, because the stock cable is to short.
Old Mar 6, 2001 | 08:57 PM
Lurch's Avatar
I'm actually using the stock clutch cable. The ProRacing bars are a KX80 bend. Actually....the stock Mojave bars are a KX80 bend too.
Old Mar 6, 2001 | 11:29 PM
Jeffksf's Avatar
I want those shocks, lets talk.
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
