1997 Polaris Xpress 300 Petcock rebuilt
Old Sep 5, 2010 | 09:06 PM
Nandy's Avatar
Default 1997 Polaris Xpress 300 Petcock rebuilt
Is there a way to rebuild this petcock? Where to get the parts?
Old Sep 6, 2010 | 05:10 AM
Since this 3 way valve is mostly plastic, hard to find parts unless you tore it apart and tried to find matching internal valve and gaskets. Not worth the trouble! Cheaper in the long run just to replace the petcock. OPT
Old Sep 6, 2010 | 10:02 AM
Nandy's Avatar
Any good source for this part? All I have found is ebay and it was $50.00!!! The problem I have with this petcock is not only that it won't stop the flow of gas to the carb (I installed an universal valve shut off for that) but that it is leaking and dripping gas into the atv which I tend to consider that a safety issue.
Thanks for all your help.
Old Sep 6, 2010 | 04:29 PM
If its truly a safety issue then cost is not the issue,its somebody's life!! Repair it properly or you could have worse problems! OPT
Overdrive's Avatar
They are not that expensive new from the dealer.
Old Sep 7, 2010 | 09:01 AM
Nandy's Avatar
I never said I was not replacing it, all I wanted was a good source for the part as I thought $50.00 is a bit steep.
Firefighter400
Oct 8, 2022 06:38 PM
slowgsxr97
Mar 18, 2022 03:40 AM
Peter_
Jul 18, 2015 07:06 AM
Unzzy66
Jul 11, 2015 10:01 PM
Coryco
Jul 6, 2015 07:30 PM
