sportsman handling
Old Sep 7, 2010 | 01:55 PM
redbank's Avatar
Default sportsman handling
Tried doing some searching on here and my question still hasn't been answered. I bought a 07 500x2 18 months ago and love the quad. The one problem I dislike is the way it handles on high speed bends, it feels like its going to roll over. One thing I did to help improve this was I installed heavy duty springs in the front (even though my quad had two hundred miles on it those stock springs were junk). Still driving on semi-hard surfaces going 30mph and over it still feels like my quad is pushing and doesn't want to make the turn. I do have the stock tires on and there is over 700 miles on the quad now, my rear springs are adjusted all the way up. I am looking at purchasing some maxxis bighorns for the quad to maybe help my situation, this tire appears to best suite my driving terrain. I don't want to go to a bigger tire because that will even create more sidewall flex, right? Should I get the original bh or go with the lighter 2.0?
Old Sep 7, 2010 | 02:17 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Just about any aftermarket tire will improve the handling vs. the oem tires. A 6ply will have less flex than a 4,3,2 you get the point. If your looking at the big horns (good all around choice!) I'd consider the 2.0's They're a bit lighter,radial which rides great, and same tread design as the original BH just not as thick of a lug. You can also pick up heavy duty rear springs which might help with body roll.
Old Sep 7, 2010 | 04:27 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
That's why the Sportsman's ride so soft!
It's a Sportsman........
I (IMO) don't think the Sportsman set-up is really made for high speed turns and great corner speeds....Caper.....
Old Sep 7, 2010 | 04:42 PM
TLC's Avatar
TLC
Don,t all Sportsmans come with 6 ply tires stock any longer?
Old Sep 7, 2010 | 06:41 PM
Unless somethings changed, NO Someone please correct me if I'm wrong but the sportsman's come with the carlisle AT-489's 3 ply or some models come with the carlisle ACT radial 3 ply. My magnum had the 489's stock which weren't completely terrible . And my 07 deluxe came with the carlisle PXT/better known as ACT's radial which handle and grip pretty good for a stock but are a little squishy in the corners. They do wear like iron though. Still trying to get them worn down to justify new zilla's this year.
Old Sep 8, 2010 | 12:18 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Had a '07 Sportsman 800 X2, same problems as you described, heavier front springs, tried a set of different tires, same result, think it is in the way the struts are designed by Polaris
Old Sep 8, 2010 | 07:07 AM
489 Stock on my 2006 Sportsman 450's.......Caper........
I like the soft front end feel...................Makes my back feel good even after a long day on the trails......125 miles +.........
Old Sep 8, 2010 | 07:14 AM
TLC's Avatar
TLC
The Sportsmans use to come with 6 ply GoodYear P Tracker stock. I quess Polaris is trying to cost save.
Old Sep 8, 2010 | 07:58 AM
Yes........There are lots of little this Polaris does to cut cost......
How about the Rear work lights that didn't comes with a switch and bulbs..?
Sure power Module From Factary is China ......and the replacement was U.S.A?
Smaller tool kits ?
Cheap hand grips?
Winches were "Warn".....Now Made in China?
No larger 2" hitch Reciever?(others have factory)
No grease Zerks anymore?
Plastic cage ...
Free Winch offer.......But NOT installed.....(no big deal for me, But for some it is)
Feel free to add more to the list........
Old Sep 8, 2010 | 08:04 AM
TLC's Avatar
TLC
Another one was the oil tank going from aluminum alloy to plastic.
