honda 400ex wont idle- plese help
Old Sep 7, 2010 | 11:06 PM
hillman1414's Avatar
Question honda 400ex wont idle- plese help
i have a 2000 honda 400ex and it will not idle on its own. i have taken the carb apart numerous times, cleaned it well, iv blown air through it, iv done everything i can think of. im not sure if it has something to do with the air/fuel mixture screw or not. if you have an ideas i could use some help because i dont know what else to do.
Old Sep 7, 2010 | 11:59 PM
Doctorturbo's Avatar
GOT BOOST!
When is the last time the valves were run?
Have you cleaned the pilot jet? Do you know what the pilot jet looks like?
Old Sep 9, 2010 | 11:25 AM
zach0199's Avatar
Is your quad stock, if not what is your current jetting?
Old Sep 9, 2010 | 09:30 PM
yes my quad is stock, iv cleaned the carb many times and it doesnt seem to help. do the jets just go bad? or could it be something more tecnical?
Old Sep 9, 2010 | 09:34 PM
and drturbo, yes i have cleaned the pilot jet, it is right next to the float, iv taken the carb all the way aprt and cleaned it throughly. but im not sure what you mean by my valves being run?
Old Sep 9, 2010 | 10:23 PM
GOT BOOST!
When was the last time the valves were adjusted?
Old Sep 12, 2010 | 09:49 PM
zach0199's Avatar
I would change out the pilot jet to a 40 or 42 and see if that helps any, also did you ajust the idle screw to see if that helps any, your air fuel screw should be 2.25 turns out i would leave it there considering you are stock. Also have you tried using the choke? I would start with the idle screw first then try the jets there only a couple bucks get the keihin ones.
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Steeldon
Sep 8, 2015 10:51 AM
DGNAZ
Sep 5, 2015 09:14 PM
