'05 Kodiak 450 Maintenance?
Old Sep 8, 2010 | 05:18 AM
Dismissed's Avatar
Default '05 Kodiak 450 Maintenance?
Hey all,
After reading up on the archives, I pulled the trigger on an '05 Kodiak 450 with 240 mi and 60 hrs. I know it hasn't been run much at all in the last few years, so its idling rough, but I think I can take care of that. Because of the low hours, I have to assume that the fluids haven't been changed in a while, so what do you recommend changing. I know oil and filter, probably air filter, but what else? I don't have a manual.
Thanks!
Troy
Old Sep 8, 2010 | 07:44 AM
papa hogg scoot's Avatar
Loved
Community Favorite
I would adj.values and changed all fluids,tighten batt.cables,also replace fuel if it,s been there an while, flush carb.also[with drain screw open]. then you should be good to go...
Old Sep 8, 2010 | 07:51 AM
TLC's Avatar
TLC
Your idling may be from bad gas,a carb cleaning would not hurt but if your lazy try a can of seafoam through a tank to clean out the carb and motor. Oil changes are done every 50hr by the book, you also have front/rear diff gear oil , tanny oil and coolant but they last much longer and should be ok for awhile yet. Would not hurt to check though.
Your ATV is the called a 450 Grizzly now,if your looking for a manual.
Old Sep 9, 2010 | 12:48 PM
CraZySteve's Avatar
Originally Posted by Dismissed
Hey all,
Thanks!
Troy
Troy
As others have said - change all the fluids (diff's/ engine oil ) test the coolant, clean the carb and grease it up!
Shoot me an email @ snowwmax@yahoo.com and I will send ya the 03-06 Kodiak 450 manual.
-Steve
dannytas
Sep 26, 2017 06:31 PM
Alex G.
Sep 11, 2017 11:38 PM
YankeeRebel
Oct 6, 2015 06:44 AM
cboler9
Sep 24, 2015 08:35 PM
caveeagle
Sep 19, 2015 01:20 PM
