banshee lowend snap
Old Mar 5, 2001 | 11:21 PM
swamplover's Avatar
I have a 2001 Banshee and love it. Its got FMF SST pipes and of course a K&N Filter. The pipes made a world of difference but I want to make my low end power and throttle response snapier, so i don't have to keep the revs up so much.. Ok Ok i know 2 bangers don't have all the low end torque in the world but I am hopin for some help. Also, What kind of tires does everybody run and in what conditions???I hear the stock tires are the best????
Thanks
Old Mar 5, 2001 | 11:33 PM
yambike's Avatar
Boyesen Rad valves or V-Force Reed cages will improve your throttle response. I had the Rad valves in my Banshee and after I installed them I didn't need to slip the clutch nearly as much to get into the power. Or if you have $2000 to spend you can get the FMF power valve cylinders. They should give you some low end snap.
Old Mar 7, 2001 | 05:01 PM
H300F's Avatar
Up your compression with a Prodesign cool head with 20cc or 21cc domes, or get your stock head milled .30 .40 or .50.
Advance your timing, with any plate they sell for $80 to $100(prodesign, trinity, engine trix, ohtonracing), or there is a way you can make your stock one like them by slotting it more or something. I forget how.
delta 2 vforce reeds and cage will increase throttle response.
You can also lighten your flywheel to make the engine rev up faster and more throttle response, but then it can make the engine want to fall below the powerband if you let of the gas or something like that, because of the less spinning mass.
Old Mar 7, 2001 | 05:56 PM
peterson's Avatar
get a set of Vitos Super stock pistons they give you lots of low end my dad has a set on his banshee all he has to do is give it a little gas and let the clutch out and he is runing a 16 gear on the front and stock on back all he's got for mods is a set of Toomey pipes and Vitos Super Stock pistons he is going to put a 17 gear on front for this summer and he just bought a cool head with 21cc domes here is a web site www.mobiledyno.com From Dustin
Kaleb_00
Jun 1, 2016 09:15 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
