Changing radiator coolant.........
Howdy all........going for a ride in the Blackrock Desert in a couple of weeks and I would like to replace the coolant in my 07 X2 500 before NoJoke's fun time. Any pointers on draining the radiator and replacing the coolant? Is there a drain plug or do you just pull the bottom radiator hose or.......?......Thanx......NoJoke
there should be a drain on the bottom, but it's just as easy to pull the bottom hose. i would make sure you put the correct antifreeze mixture back in or at least a 50/50 if you cant find the 60/40 mix. it's very important you get all the air out or you'll have over heating issues for sure. good luck.
Logan Collins
Sep 5, 2015 08:03 PM
