Changing radiator coolant.........
Old Sep 10, 2010 | 09:30 PM
NoJoke's Avatar
Default Changing radiator coolant.........
Howdy all........going for a ride in the Blackrock Desert in a couple of weeks and I would like to replace the coolant in my 07 X2 500 before NoJoke's fun time. Any pointers on draining the radiator and replacing the coolant? Is there a drain plug or do you just pull the bottom radiator hose or.......?......Thanx......NoJoke
Old Sep 11, 2010 | 05:28 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
there should be a drain on the bottom, but it's just as easy to pull the bottom hose. i would make sure you put the correct antifreeze mixture back in or at least a 50/50 if you cant find the 60/40 mix. it's very important you get all the air out or you'll have over heating issues for sure. good luck.
panicmanic
Sep 28, 2015 12:59 PM
bigbear350quad
Sep 11, 2015 12:40 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Logan Collins
Sep 5, 2015 08:03 PM
