Factory wired winch
Old Sep 14, 2010 | 09:25 PM
molonlabe's Avatar
Default Factory wired winch
I recently bought a 2010 Sprtsmn 850 and the dealer told me it was prewired for a winch, I can't find anything in the owner's manual and I'm looking to purchase a winch. What will work with factory wiring?
Old Sep 14, 2010 | 09:58 PM
Fishy MN's Avatar
Sportsman XP Polaris 3500 LB Winch Part #2877820 Would be the easiest, everything you need and easy install with the factory pre-wiring.
Old Sep 14, 2010 | 09:59 PM
Mongrol's Avatar
"Official Site Skeptic"
Look for a blue and a yellow cable near where the winch mounts. THATS IT.
Old Sep 14, 2010 | 10:17 PM
hallj86's Avatar
Any whinch will work pre wired means that there is 8 guqge wire ran from the batt to the front of the qtv and there is a power outlet for the switch to plug into under the pod.
Old Sep 14, 2010 | 11:16 PM
molonlabe's Avatar
Thank Y'all for the info
Old Sep 16, 2010 | 12:59 PM
JK500sp's Avatar
Any winch will work but if you try to put just any solenoid in the spot were it goes the prewiring will have to be altered. I put a polaris warn winch on one of mine, and it went flawlessly. Then i thought i would upgrade to a RT2500 big mistake i had to cut all my tie straps on the original harness and reroute the cable around the fuel tank to fit on the solenoid. GO with Polaris Warn winches save the headache, and same power.
COFatboy
May 2, 2020 12:06 AM
toonces
Oct 19, 2015 02:21 AM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
