speedometer not working ....no lights ?
Hello everyone , I have a 2001 polaris 500 sportsman and the speedometer doesnt light up or even work .....the four wheel drive works thow . can someone point me in the right direction . Thanks !
If the AWD still works,then then either your Hall Effect senors by the right front brake rotor quit (like mine ) or the wire from the senor to the speedo disconnected. Mine has not worked for 3 years now the only thing that works is my hour meter without a good sensor.
My speedo all lights up though.
maybe just a Burnt out bulb in the speedo? Take the pod cover off to check it out.
hi,
I just repaired my 2000 sportsman 500 today.
it had the NO LIGHTS, NO SPEED (needle), NO HOURS (digital), and NO MILEAGE (digital)issue.
The speedometer head comes apart by gently bending the metal brezel up, then the needle pulls straight up (note where you have it positioned)
there are 3 screws under the numbers, you need to peel the plastic label up carefully.
from there the back has 2 large black electrolitic capacitors and a 3 legged SRC transistor next to them. That transistor part needs replaced.
It is a Motorola TIP 48 voltage regulator.
Mine looked fine visuially and after much convincing I pulled it and replaced it and saved my self$ 250.00
need more help--email me at Apark3@woh.rr.com
I have a bunch of these transistors, had to buy 50.
bzdok1234
30
Feb 23, 2016 01:55 PM
