2003 kodiak battery not charging
kodiak will start with a charged battery and run,put multimeter on battery and watch voltage start dropping and when voltage is under 12 volts,the starter solenoid starts clicking when you try to crank.can anyone help?
Shoot me an Email - I have the service manual for 03-06 Kodiak 450's (that is if yours is a 450) But then again - I am sure the troubleshooting tips are the same for a 400
snowwmax@yahoo.com
snowwmax@yahoo.com
battery volt before starting 11.55v ,crank up and volt at idle 11.55,rev up rpms jumps to 14.17 and then jumps around up to 16.02v,then drops back to around the 11.55 v while reved up. checked connection on voltage regulator and it was so hot ,don't know how hot regulator suppose to get ? do I need to swap regulator?
