yfz 450 help?
Old Sep 23, 2010 | 06:24 PM
alexripper13's Avatar
Default yfz 450 help?
I have a YFZ 450R that runs great when turned on but when the engine is stalled the quad refuses to turn on with out the help of a battery pack starter that i carry when we go riding.
Is the problem the battery or is it something else?
I would greatly appreciate any feedback
Old Sep 23, 2010 | 09:05 PM
kevin773's Avatar
well, if it starts fine with the help of an external battery source, I would bet its the battery.
Old Sep 25, 2010 | 12:16 AM
danatack's Avatar
Definetly would look at the battery, and connections, also if you got a manual or have access to one ck- the charge cicuit flow chart.
Old Sep 29, 2010 | 11:22 PM
kevin773's Avatar
yeah, Its probably the battery, if it were the starter or solenoid or somethin, it wouldnt turn over when you give it juice
Old Oct 5, 2010 | 05:00 PM
EPI Brandon's Avatar
Before installing a new battery use a multimeter and goes from postive and and negative on the battery checking dc voltage with machine running charging system should be at 13.5vdc to 15.0vdc. any lower and you could have a charging system problem.
Old Oct 5, 2010 | 10:57 PM
DODGE57HEMI's Avatar
Mopar Man!
x4 On the batt!
