help!
Old Sep 25, 2010 | 10:36 AM
andre1's Avatar
Unhappy help!
I have a 93 polaris trailboss 250, it keeps dying out on me after an hour of riding any thoughts on the problem?
Old Sep 25, 2010 | 11:47 AM
TrailblaznSonny's Avatar
Check ignition circuit. Sounds like something may be getting hot and breaking down. Fuel vent too, but I do not think you would make it an hour if that were the case. Never hurts though.
TB
Old Sep 25, 2010 | 08:25 PM
After cooling down does it start back up? Check compression if you can cold and after it stops,could be time for a top end. Check for fire to the plug also.
Old Sep 26, 2010 | 08:22 AM
ftwflh's Avatar
DITTO!!!!!!!!!! Most people mistake low compression for either a carb problem or a electrical problem.Most the time these 2strokers just need to be freshened up(most the time this is the cheapest fix)
Old Sep 26, 2010 | 09:24 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you need at least 100 psi of compression which gets less when it gets hot.
