About Tires in my 850
Old Sep 25, 2010 | 06:28 PM
zeus-fl's Avatar
Default About Tires in my 850
I am thinking change tires for betters mud tires. Mud Lites or Gorillas.
The question is. With the stock suspension in a 850 xp 2010 can i use tires 28, 29 or 30 inches ?
Old Sep 25, 2010 | 10:06 PM
switzomatic's Avatar
Not sure on the size but you can typically go up 2 inches from stock on the popos. As for the choice on tires it depends on where you ride mostly. Mud lites are a decent mud tire and good all around tire. Gorillas are very aggressive and will not be so good on normal trail rides.
Old Sep 26, 2010 | 07:51 AM
zeus-fl's Avatar
Any one know if 29 or 30 will fit without lift kit or spacers ?
Old Sep 29, 2010 | 10:57 AM
xtr man's Avatar
you don't need a lift but it will be tight especially when acclerating hard but spacers or offset rims are needed you will need at lest a one inchif you go with 11" width
1.5" for 12"
Old Sep 29, 2010 | 11:04 AM
TLC's Avatar
TLC
what I like about Mudlits is the choice of 3 models, Trail tire (AT) with 3/4" lugs, Trail/Mud (XL) with 1-1/8th lugs. and Mud (XXL) with 1-1/2" lugs. all are 6 ply with the same tread pattern.
Old Sep 29, 2010 | 11:50 AM
zeus-fl's Avatar
what the specification if i want the ITP SS312 rims with a 28 mud lites ?
Old Sep 29, 2010 | 06:56 PM
HIGHOCTANE's Avatar
1.5" for 12"
I believe they fixed the swaybar clearance issue on the 2010...so 11" wide tires should fit without any spacers...someone correct me if I am wrong.
Also..30's will probably fit..only issue I could think of would be the front tires possibly hitting the plastic underneath during hard spring compression...and maybe hitting something when turning??
I had 32's on my 850 with a 3" lift...the only thing even close to rubbing was the rear tires...had to trim the back of the foot wells..
Old Sep 29, 2010 | 07:02 PM
HighVelocity's Avatar
I run 12" Zillas on the back of my '10 850. No spacers and no clearance issues.
Old Sep 30, 2010 | 07:39 AM
zeus-fl's Avatar
Thats sound like good news. Is any advantage using spacers? Better ride? Goods vs Bads?
Old Sep 30, 2010 | 04:11 PM
helmethair78's Avatar
I had mud lite XLs. They are not a good tire and I will never own them again. They are not a mud tire....
