Honda atc 185
Old Sep 27, 2010 | 09:24 PM
fumminsplease's Avatar
Default Honda atc 185
Hey guys, I just picked up a free three wheeler out of a pile of scrap metal and I took it home cleaned it up a little bit and cleaned the carb and it fired up for about a minute. Then the recoil broke and after about three hours of wrestling with it I got it back together and on. But now the problem is when I pull it over the intake blows and the exhaust sucks. I am lost here, can anyone help?
Old Sep 27, 2010 | 09:52 PM
red kaw 84's Avatar
I saw this kind of problem once before, it turned out that the motor was being turned over backwards. I know this sounds odd, but it does happen. Good luck.
Old Sep 29, 2010 | 10:56 PM
So I take it I have the only atc 185 in the world that has ever done this?
Old Oct 3, 2010 | 11:04 PM
ktmbk's Avatar
seems so-
There's an old story of someone that drove up a hill, stalled, and went down backwards, resulting in a bike that the engine ran backwards. I doubt it really happened since the bike won't run using the carb as an exhaust, but it's funny to tell.
However, remember that an engine is just an air pump, it will pull air from one direction to the other. You can turn this "pump" over in the wrong direction with enough force and pump air backwards.
Somethings wrong. AT first I would say the problem would have to be with the pullstart. The cable could be wrapped backwords, however an issue would come in with the little through out prongs that come out internally when it spins. From there issues get worse.
The whole pull start assy probably needs to be rebuilt, not always an easy thing. get a manual and follow it and everything should be ok. It's a good start and my best guess.
Good lock and post how you do.
Old Oct 4, 2010 | 09:49 PM
well I just checked the recoil and that checks out good - pulls over correctly and fine. I think the timing could be off but not sure, but now I found another problem. I cant get any spark and I checked the plug, wires, kill switch and am starting to think it is the cdi box or coil. Not sure but its a start.
Old Oct 4, 2010 | 10:59 PM
nickdodd25's Avatar
Mabe the timing jumped a coupel teeth, If it sat awhile the cam chain tensener might have got weak and the chain jumped.
Old Oct 5, 2010 | 10:06 PM
kind of what im leaning towards but cant figure out how im going to fix it
Old Oct 7, 2010 | 04:23 PM
nickdodd25's Avatar
Its really easy to check the timing, well thats if you have a parts manule. if you do look for valve timing and it will show you how and it prolly only take a half hour.
Old Oct 7, 2010 | 04:51 PM
unit6666's Avatar
I have an interesting story involving backwards engines.. when I was a young pup a friend of mine had a KX80 dirtbike one day he fired it up wound it up dumped the clutch and it went backwards.. It only happened once and i saw this with my own eyes.. it doesnt seem possible but I DID SEE IT!!!
Old Oct 7, 2010 | 11:06 PM
nickdodd25's Avatar
I have too but it was a 2 stroke, 4 stroke cannot run backwards. Was funny as hell when my cousin dunped the cluch and he fell over cause the bike went backwards!!
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
