fan
Old Oct 1, 2010 | 08:42 PM
thestig's Avatar
Default fan
i know a lot of Guys have been burning up fans. they have to replace it as a whole unit.
i just need the blade! i broke mine and motor is fine.
so if you know anyone who just replaced their fan and has one with a pooched motor i can take the fan from them
thanks
Old Oct 2, 2010 | 12:08 AM
TLC's Avatar
TLC
Might as well just get the whole fan new from SPAL .COM thats where Polaris buys them from but spals sells them for $85. Not $250 like a dealership. I got one for $65 from ebay ,my dealership wanted $320 Canadian.LOL
What ATV do you Have?
Old Oct 2, 2010 | 04:49 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
as mentioned, maybe check ebay. most likely just as easy to replace whole unit. imo
Old Oct 7, 2010 | 05:40 PM
thestig's Avatar
i got a fan from summit racing . 50 bucks
http://www.summitracing.com/parts/PR...ype=10(picture is wrong is has a rear grille)
exact fit, almost fits better than stock unit. higher cfm and rear housing has grille to protect from debris. can't even tell its running with quad running. and blow ways more air.
just needed 4 rubber shims so mounts holds fan flush to shroud
Old Oct 7, 2010 | 06:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds good. glad you got a good one and thanks for the info.
Old Oct 8, 2010 | 06:32 AM
TLC's Avatar
TLC
Just Remember to put the DC leads on right so the new fan rotates the correct direction. The fans are meant to pull, not push. I made that mistake LOL.
Old Oct 8, 2010 | 07:45 AM
thestig's Avatar
this one was made as a puller. and yup i got it right
Old Oct 8, 2010 | 09:43 PM
Northstar2's Avatar
My new project (99 sportsman 500) has a toggle switch to turn the fan on, and when its on it doesnt sound very healthy. So I'd guess I should get a temp sender of some sort, and maybe a Summit fan? Anyone know what temp I should be looking for, so I can use a cheap automotive sender instead of a big dollar dealer part?
Dont want to run it this way for long, but can I just turn it on when the red light comes on, or is the red light too late?
Old Oct 10, 2010 | 09:55 AM
Kerbbirds's Avatar
Red light is too late , as for the sender , get a Wells # SW-526from the auto parts store, may have to ghange the plug end, Napa # is FS-147
Old Oct 11, 2010 | 07:55 AM
TLC's Avatar
TLC
If your Polaris switch is a 4010161 you can use a Napa FS 147 ,Wells SW526 or BlueStreak TS-127.
All your looking for is a screw into the rad thread size of M16X1.5
