1998 scrambler 400 stator values
Old Oct 4, 2010 | 03:25 PM
HSR's Avatar
HSR
Default 1998 scrambler 400 stator values
I need the resistance values for a 1998 scrambler 400 stator.It has intermittent/no spark.
Steve
Old Oct 4, 2010 | 05:22 PM
ftwflh's Avatar
Not sure on the values to check but if you end up needing one let me know I may have a used one that would work.
Old Oct 4, 2010 | 06:51 PM
Overdrive's Avatar
Have you had any problems with your pull start mechanism?. A lot of times intermittent/no spark is caused by debris from a messed up pull start getting into the stator and bending the pulse coil away from the flywheel.
If the pulse coil is bent too far away you will have no spark. Slightly bent intermittent spark.
Old Oct 7, 2010 | 07:46 PM
HSR's Avatar
HSR
ttt
ultangler
Nov 30, 2024 01:35 AM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
