wolverine 450 wont start
Old Oct 4, 2010 | 09:39 PM
miassmaro98's Avatar
Default wolverine 450 wont start
hey guys it turns over fine,has spark,and carb is perfectly clean.i was out riding it perfect and it turn off on me and thats the last it ran.what can it be?timing?can that lil computer thing cause it to not run
Old Oct 5, 2010 | 07:55 AM
HeftyLefty's Avatar
Pull plug,spray with starter fluid, reinstall and see if it will start. That should tell you if it's fuel or ignition. And since you have the plug out, check compression. Any gunk in fuel tank?. Is the fuel shutoff valve working properly?. Carb float OK?.
Old Oct 5, 2010 | 09:30 AM
Jaster94's Avatar
pop the hose off of the carb and see if you have fuel flow, it may be a plugged petcock valve, plugged fuel filter, etc.... it you've got spark-that's half the battle. when you say clean, you see daylight through all of the orifices on the jets, right?! when machine turns over, does it act like it is trying to fire or just turns over. let us know.
Old Oct 5, 2010 | 11:08 AM
It back fires after couple of turns,but won't turn on
Old Oct 5, 2010 | 04:55 PM
EPI Brandon's Avatar
I would check compression if that reads low mostly you need to adjust the valves. your question about the cdi box the machine will never have spark if the cdi is bad or if it does very intermitent.
Old Oct 6, 2010 | 01:17 AM
thank you i forgot what that was called,so check compression is my next big step.what numbers should i see on the gauge?
Old Oct 6, 2010 | 08:12 AM
Normally most yamaha call for 120 and up. but evan if you have 105 or sumthin allittle higher it should run.
Old Oct 6, 2010 | 02:33 PM
okay thanks will have to borrow a comp. gauge
Old Oct 12, 2010 | 04:30 AM
went out and bought a compression gauge set,did a test and im getting about 101-102.is that enough to run?what sucks the most my extended warranty ended few months back
Old Oct 12, 2010 | 10:20 PM
well i checked it
