wolverine 450 wont start
hey guys it turns over fine,has spark,and carb is perfectly clean.i was out riding it perfect and it turn off on me and thats the last it ran.what can it be?timing?can that lil computer thing cause it to not run
Pull plug,spray with starter fluid, reinstall and see if it will start. That should tell you if it's fuel or ignition. And since you have the plug out, check compression. Any gunk in fuel tank?. Is the fuel shutoff valve working properly?. Carb float OK?.
pop the hose off of the carb and see if you have fuel flow, it may be a plugged petcock valve, plugged fuel filter, etc.... it you've got spark-that's half the battle. when you say clean, you see daylight through all of the orifices on the jets, right?! when machine turns over, does it act like it is trying to fire or just turns over. let us know.
Normally most yamaha call for 120 and up. but evan if you have 105 or sumthin allittle higher it should run.
well i checked it
